Hot water tank temperature control
sasquatch16
Member Posts: 10
in Oil Heating
I have a oil fired boiler with a zone valve that feeds a coil in a storage tank for domestic hot water. Water is very hot and boiler seems to cycle a lot. I have enclosed a picture of control on tank. I think the way it is sitting temperature is turned all the way up. Would turning dial counter clockwise turn temperature down?
Yes. That's a Honeywell aquastat...a thermostat for water. It is adjustable by the temperatures listed on the dial.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
No numbers on dial. Am I correct that dial should be turned CCw to lower temperature
I've never seen a Honeywell aquastat with no numbers on the dial, but if that's the case, I'd assume it's a fixed operating temperature. And if that's the case, it's unacceptable as a domestic hot water control.
My advice is to swap it out with one of these:
https://www.supplyhouse.com/Honeywell-L4006A2007-High-or-Low-Limit-Aquastat-100-240F-range-5-30F-Adj-DifferentialContact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Are you able to see picture I posted? There is a dial that moves. I’ll play with it going both directions.0
are you sure there are no numbers stamped into that dial?
and post a picture of that label above the control,
and of any label from under the control cover if there,
did you try googling the control model # ?known to beat dead horses0 -
Although hard to see, there are temp numbers or lo-med-hi-ouch.
Sometimes a flashlight shown at an angle helps.
"Normal" domestic hot water temp is 120° but dont go higher without a mixing valve.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
