At AHR
hot_rod
Member Posts: 22,199
A few of my favorites.
Smart money should be shopping for small A2WHP's. As always finding small sizes is a key for apartments, condo, small and also super efficient homes. One version from this company allow you to duct air in and out, so the entire unit is inside out of the elements. They use name brand components Danfoss, SWEP, Emerson, Seimens, not knock off parts. Some 5& 6 KW offerings.
Lochinvar partnered with a Danish company for this top quality Cogen, about 25KW. They pull heat from exhaust, cooling, generator, and even oil cooler I think. With a good consistent thermal load in a high KW area it could be a good solution.
An intelligent condensate tank from IntelliHot.
Plastic ducting system from CentroTherm
Any steam?All Steamed Up, Inc.
Consulting3 -
You can have it good, fast or cheap. Pick two3
Rick Mayo stopped by and gave me an update on new Taco offerings. I cruised by a few times, your booth was always busy, a good sign.
The heat pump was intriguing, seems like a good idea to diversify the offering.Bob "hot rod" Rohr
Yep - really busy show. Likewise busy at your booth when I did a few fly-bys. Reaction on the air to water heat pump was pretty darn good. After all, we are in the fluid moving business...0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
