At AHR
hot_rod
hot_rod Member Posts: 27,348
A few of my favorites.
Smart money should be shopping for small A2WHP's. As always finding small sizes is a key for apartments, condo, small and also super efficient homes. One version from this company allow you to duct air in and out, so the entire unit is inside out of the elements. They use name brand components Danfoss, SWEP, Emerson, Seimens, not knock off parts. Some 5& 6 KW offerings.
Lochinvar partnered with a Danish company for this top quality Cogen, about 25KW. They pull heat from exhaust, cooling, generator, and even oil cooler I think. With a good consistent thermal load in a high KW area it could be a good solution.
An intelligent condensate tank from IntelliHot.
Plastic ducting system from CentroTherm
Robert O'Brienkcopp
    Steamhead Member Posts: 18,413
    Any steam?
    Consulting
    Robert O'BrienCanuckerSolid_Fuel_Man
  • Canucker
    Canucker Member Posts: 723
    > @Steamhead said:
    > Any steam?
    Probably only at the espresso machine ;)
    You can have it good, fast or cheap. Pick two
    Erin Holohan HaskellkcoppSolid_Fuel_Man
    Steamhead said:
    Any steam?
    Big commercial and industrial steam manufacturers, didn't see much residential steel stuff, nothing real new anyways.
    Canucker
  • Anyone show you our new 0018e with Bluetooth?
    JohnNYkcopp
    Rick Mayo stopped by and gave me an update on new Taco offerings. I cruised by a few times, your booth was always busy, a good sign.
    The heat pump was intriguing, seems like a good idea to diversify the offering.
  • Yep - really busy show. Likewise busy at your booth when I did a few fly-bys. Reaction on the air to water heat pump was pretty darn good. After all, we are in the fluid moving business...
