Boiler percolating
BobSers
BobSers Member Posts: 1
Customer has a Small Slant Fin cast iron boiler attached to an old gravity radiator system with large pipe diameters, two pipe reverse return. Boiler is twenty years old and started percolating. In my experience this only happens when a system has a leak and feeding make up water. No leaks here. What cleaning solution to use to mitigate the deposits? I'm thinking of flushing like a tankless water heater with something a bit stronger than vinegar. Thoughts? Percolation sound telgraphs through the piping and is loud at first floor radiators. Boiler temp is below 180.
    Jamie Hall Member Posts: 27,032
    Almost certainly scale buildup in there. I do steam, so I have no idea what -- besides vinegar -- might work, although I do know there are a variety of products out there.
  • JUGHNE
    JUGHNE Member Posts: 11,528
    If this has an open top expansion tank at the top of the system that could be a source of oxygen introduced into the system.
  • GBart
    GBart Member Posts: 746
    Is it percolating or thumping, we had some SF boilers that had funky castings and they trapped air inside the water jacket, there was no way to get it out. As the boiler ran it started thumping like drums, it reverberated in the chimney and upstairs, changing the block was the only recourse.
    In your case, an old gravity system hooked to a small boiler, you may have cleaned the pipes into the boiler and filled it with mud, mud doesn't transfer heat well and takes a lot more btu's.
  • ch4man
    ch4man Member Posts: 298
    yep, saw that twice about 3 years ago or so
  • lchmb
    lchmb Member Posts: 2,997
    had my own boiler do that.. bottle of 8 way and quiet as a mouse...
  • ChasMan
    ChasMan Member Posts: 474
    I used the Rhomar water treatment in my Slant Fin. The product was Hydrosolv 9100. I ran it for a month and then flushed it and ran it again for another month. I did a 25 to 1 mix. It did not fix it 100 percent but 95 percent. I suspect the noise now is bits of stuck scale, stuck in passages. You need to put your ear against the jacket to hear it.
