Replacing Hoffman with Gorton
Mattm15
Mattm15 Member Posts: 10
Hey guys,
So last I posted I mentioned the incredibly loud floor to ceiling pipes on the top floor of my pre-war NYC apartment. I've bought a Gorton No. C air valve to replace the Hoffman #43 that's there now. The only problem is that -- while both have 1/4" openings -- the exterior of the Gorton C is a bit larger than that of the Hoffman and thus cannot fit into the pipe. I've included pictures below as reference.
My question is this: is there anyway of remedying this? Is there an extension pipe that I could attach? Or perhaps a different Gorton? Something?
As always, thanks in advance!
    Steamhead Member Posts: 18,439
    How much headroom do you have between the opening for the vent and the ceiling?
    Consulting
  • Gordo
    Gordo Member Posts: 857
    edited January 2019
    It looks like the Hoffman is 1/8" NPT (national pipe thread), while the Gorton you have is 1/4" NPT (?). You can buy a brass adapter (1/4" female NPT to 1/8"male NPT) or return the 1/4" Gorton and get an 1/8" Gorton.
    CLamb
  • Mattm15
    There's about 8 inches from pipe to ceiling. I've included a picture below. And is that the case (that it's 1/4 and not 1/8)? My landlord said that it was a 1/4" hole, but I think that you're right. The holes are both 1/4" wide; it's the exterior that's super thick on the Gorton. Maybe I could just buy the adapter.
    As always, thanks for your input, everyone
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    If only your landlord would say, "I'll turn down the pressure, and catch up with the maintenance of the system. Thanks for bringing this to my attention, so i can reduce my gas bill 30%, and prolong the life of my boiler!"--NBC
    Mattm15
  • gfrbrookline
    gfrbrookline Member Posts: 788
    Since you haven't installed it I would return it and get the correct 1/8 npt.
    Mattm15
