Removing a stubborn steam plug
branimal
Member Posts: 260
I’ve got an extra steam radiator that I’d like to install where one was installed at some point. The steam pipe is plugged with a 1/2 plug. I’ve hit it with heat for 1 minute and tried to open it with my wrench, no luck. I’m afraid to break the plug. Any suggestions?
And what is that bell shaped thing below the plug?
My replacement plan is a 1/2 close black nipple attached to a 1/2” female x 1” male fitting. That’s the best I could find in my hardware store. My radiator valve is 1” female.
Try a good penetrating oil, applied several times over a few days. The bell thing looks like a reducer, maybe the pipe is the same size as the one next to it?
Thanks I’ll hit it with some pb blaster0
You need bigger tools than a pair of channel locks. Heat the outside to get thermal differential working for you, then ice down the plug to shrink it. That differential shock helps break the rust bond. Then hit it with Kroil/PB Blaster when it is still warm to draw the oil in. Keep at this for a few cycles. Then on the last, shock it and lean into it with a couple big wrenches.
I find impacts to work better in these situations but you'd need a square socket and a big impact. My 18V 1/2" anvil Makita buzzes those things out like they weren't even stuck.Peter Owens
SteamIQ2 -
I tried with a 12" pipe wrench.
I'll use your heat/cool/oil method with an 18" pipe wrench.0 -
@JUGHNE has it. Ignore that plug, the bell reducer needs to come off as well. 1/2" piping doesn't belong on a 1 pipe system. They probably did it that way because the fittings were laying around so they used them, I only suggest that based on my past experience doing just that.4
branimal.
Do you have two PIPE WRENCHES? 18" or greater in size will turn that reducing coupling. Or larger if you can get them. But you should use two. One as a backer the other to loosen.
Can you pull the fitting reducer up off the floor by hand?
If you can, place one wrench between the fitting reducer and the floor on to the pipe, the other wrench on the fitting reducer.
If you can't pull the reducer up a little from the floor, hopefully you can access the pipe from below . You will need some help.One person holding one wrench from below and the other loosening from above.
If those things don't work, you can try turning with just one wrench from above as a last resort. This can turn the pipe in the floor that is not exposed and create more problems so hopefully you can get it from the other recommendations.
("lefty loosey righty tighty").
Good luck. Please post your end results.2 -
Doesn't look like a BCI fitting. Looks malleable....?
Would be better if it's black cast iron.0 -
One useful trick not mentioned is to hit the plug a few good whacks with a hefty hammer. The impact shock is frequently all that is needed to loosen things up.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
Probably cast iron swing 90's under the floor.
Those would "whack crack".
I did crack a CI tee unscrewing a nipple. Didn't show up until I tried to reuse for new nipple.0 -
Yes its a one pipe system.
I cannot pull the reducer fitting up. Won't budge.
I can ask my tenant below to access through his ceiling.
I've got a 12" and an 18" wrench. I'll give that route a try.
I recently moved a 2" CI steam pipe and I needed to put relief cuts in the couplings and hammer and chisel it out. The pipe threads were in good shape afterwards.
Regarding the water hammer... i disconnected a radiator yesterday and it had maybe 30 ounces of water in it because the pitch was terrible. But it never hammered. I thought water in the radiators made them hammer?0 -
It _can_, but I’ve given up being sure about such things 😂
Have you described your main steam boiler piping, as that can throw up a lot of water, if it is not correct, especially if the pressure is too high, and the main venting is inadequate.—NBC0
A few years back I replaced the anode rod on my gas hot water heater. It took a 24" breaker bar with a 1-1/16" six point socket and a four ft cheater on that 24" breaker bar. I ilso had a buddy trying to hold the tank but I still moved it.
3PSI gauge2 -
Bought a square socket from amazon and borrowed my brother's cordless impact wrench. The plug came right off.Sailah said:
I'm going to temporarily use a 1/2" nipple along with 1/2" x 1" bushing to hookup the radiator. In 3-4 months I'll be gutting this apartment and I can upgrade to 1" fittings so there is no bottleneck.
Thanks guys.
Remove the anode rod !? Have a helper put a bear hug on the water heater !🔩0
That’s a 1x1/2 Black malleable coupling, remove it completely and connect to radiator. Use an 18” or 24” wrench.0
