Removing a stubborn steam plug
branimal
branimal Member Posts: 286
I’ve got an extra steam radiator that I’d like to install where one was installed at some point. The steam pipe is plugged with a 1/2 plug. I’ve hit it with heat for 1 minute and tried to open it with my wrench, no luck. I’m afraid to break the plug. Any suggestions?
And what is that bell shaped thing below the plug?
My replacement plan is a 1/2 close black nipple attached to a 1/2” female x 1” male fitting. That’s the best I could find in my hardware store. My radiator valve is 1” female.
    ethicalpaul Member Posts: 8,752
    Try a good penetrating oil, applied several times over a few days. The bell thing looks like a reducer, maybe the pipe is the same size as the one next to it?
    branimal
  • branimal
    Thanks I’ll hit it with some pb blaster
  • Sailah
    Sailah Member Posts: 826
    You need bigger tools than a pair of channel locks. Heat the outside to get thermal differential working for you, then ice down the plug to shrink it. That differential shock helps break the rust bond. Then hit it with Kroil/PB Blaster when it is still warm to draw the oil in. Keep at this for a few cycles. Then on the last, shock it and lean into it with a couple big wrenches.
    I find impacts to work better in these situations but you'd need a square socket and a big impact. My 18V 1/2" anvil Makita buzzes those things out like they weren't even stuck.
    Peter Owens
    SteamIQ
    branimalethicalpaul
  • branimal
    I tried with a 12" pipe wrench.
    I'll use your heat/cool/oil method with an 18" pipe wrench.
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Assuming this is one pipe steam.
    IMO I believe you need to remove the reducing coupling and use the full size pipe. Adding the 1/2" nipple and then increasing to valve size will create a bottleneck (actually an hourglass) to cause water hammer.
    Do you have access to the riser below?
    branimalkcoppGrallert
  • KC_Jones
    KC_Jones Member Posts: 5,933
    @JUGHNE has it. Ignore that plug, the bell reducer needs to come off as well. 1/2" piping doesn't belong on a 1 pipe system. They probably did it that way because the fittings were laying around so they used them, I only suggest that based on my past experience doing just that.
    2014 Weil Mclain EG-40
    branimal1Matthiasethicalpaulkcopp
    EBEBRATT-Ed Member Posts: 20,155
    edited January 2019
    As @jughne & @KC_Jones mentioned the reducer needs to come off. They didn't have the right size cap so they put a reducer on and plugged it.
    branimal
  • Intplm.
    Intplm. Member Posts: 3,005
    branimal.
    Do you have two PIPE WRENCHES? 18" or greater in size will turn that reducing coupling. Or larger if you can get them. But you should use two. One as a backer the other to loosen.
    Can you pull the fitting reducer up off the floor by hand?
    If you can, place one wrench between the fitting reducer and the floor on to the pipe, the other wrench on the fitting reducer.
    If you can't pull the reducer up a little from the floor, hopefully you can access the pipe from below . You will need some help.One person holding one wrench from below and the other loosening from above.
    If those things don't work, you can try turning with just one wrench from above as a last resort. This can turn the pipe in the floor that is not exposed and create more problems so hopefully you can get it from the other recommendations.
    ("lefty loosey righty tighty").
    Good luck. Please post your end results.
    branimalethicalpaul
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    What about cracking the fitting with 2 big hammers, or making lateral cuts in it to relieve the hold on the threads.
    Put a big pair of vice-grips on the pipe in case it wants to fall down the hole under the floor.—NBC
    ethicalpaulGrallert
  • Intplm.
    Doesn't look like a BCI fitting. Looks malleable....?
    Would be better if it's black cast iron.
  • Pumpguy
    Pumpguy Member Posts: 799
    One useful trick not mentioned is to hit the plug a few good whacks with a hefty hammer. The impact shock is frequently all that is needed to loosen things up.
  • JUGHNE
    Probably cast iron swing 90's under the floor.
    Those would "whack crack".
    I did crack a CI tee unscrewing a nipple. Didn't show up until I tried to reuse for new nipple.
  • branimal
    Yes its a one pipe system.
    I cannot pull the reducer fitting up. Won't budge.
    I can ask my tenant below to access through his ceiling.
    I've got a 12" and an 18" wrench. I'll give that route a try.
    I recently moved a 2" CI steam pipe and I needed to put relief cuts in the couplings and hammer and chisel it out. The pipe threads were in good shape afterwards.
    Regarding the water hammer... i disconnected a radiator yesterday and it had maybe 30 ounces of water in it because the pitch was terrible. But it never hammered. I thought water in the radiators made them hammer?
    magewick
    edited January 2019
    It _can_, but I’ve given up being sure about such things 😂
    edited January 2019
    Have you described your main steam boiler piping, as that can throw up a lot of water, if it is not correct, especially if the pressure is too high, and the main venting is inadequate.—NBC
  • Intplm.
    Use the 18" to loosen and the 14" as your backer below the floor if thats possible.
    Hope that you do not need to cut the fitting as you had before.
    Maybe put a cheater bar/long piece of pipe on the 18 to extend the leverage and make your turn.???
    branimal
  • BobC
    BobC Member Posts: 5,565
    A few years back I replaced the anode rod on my gas hot water heater. It took a 24" breaker bar with a 1-1/16" six point socket and a four ft cheater on that 24" breaker bar. I ilso had a buddy trying to hold the tank but I still moved it.
    Bob
    3PSI gauge
    adasilvabranimal
  • kcopp
    kcopp Member Posts: 4,669
    I would just cut it w/ a good Sawzall blade and after you get 7/8 through the fitting split it w/ a cold chisel.
    ethicalpaulGrallert
  • branimal
    Bought a square socket from amazon and borrowed my brother's cordless impact wrench. The plug came right off.
    I'm going to temporarily use a 1/2" nipple along with 1/2" x 1" bushing to hookup the radiator. In 3-4 months I'll be gutting this apartment and I can upgrade to 1" fittings so there is no bottleneck.
    Thanks guys.
  • Sailah
    Nice!! Everyone that tries mine is:
    "Huh, that's pretty awesome. I should get one. Or I could always borrow yours right?"
    Peter Owens
    SteamIQ
    branimal
  • branimal
    While I have the impact wrench I'm going to attempt to remove my water heaters anode rod!
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,088
    Hi, That's a good idea! Best if you use a 1-1/16" six point socket, and grind down the face of the socket so it's flat. This gives the best bite on the head of the anode. ;)
    Yours, Larry
    ethicalpaulbranimal
  • Intplm.
    Good to hear @branimal . Thanks for posting your results.
  • JUGHNE
    I am curious to hear (perhaps literally ;) ) how that rad works with the bottleneck/hourglass. Good experiment I think.
    Intplm.
  • Intplm.
    Remove the anode rod !? Have a helper put a bear hug on the water heater !🔩
  • 71montess
    71montess Member Posts: 1
    That’s a 1x1/2 Black malleable coupling, remove it completely and connect to radiator. Use an 18” or 24” wrench.
