White Rodgers 11C30-3
HotanCool
Member Posts: 57
Obsolete,no helpful pdfs. Can anyone fully explain the dials. Both low&high have a silver pointed dial on top of the black temp adjustment. I've Always been a little baffled by it. Is it a stop? A differential? It can set apart from where the actual temp is set to,but what's its actual purpose?
Is that a dual aquastat?
Pics?0 -
The lo limit had a silver dial, seperate from the actual temp setting indicator. High limit has a gold one. Seen a lot of these,never knew why exactly.0
Looks like it is set for 170* on and 190* off.0
They are differential settings.
If your not using a tankless coil there's much better, shall we say system friendly aquastats. In a lot of ways.
What provides domestic hot water?0 -
It's an old boiler,heat only. I've seen a lot them controls in my day. Just curious about the two indicators together on the right side dial,how they work together. Never did look much into it before,but I was just curious. I figured some sort of differential. And yes,agree,much better replacements today.0
So can you explain how the differential is set with these dials?0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
