Hartford loop ?
heatinghelpfor3
Member Posts: 17
Hi,I have a steam / No.2 oil heating system, there are 17 radiators in the house (5 on the 3rd floor-5 on the 2nd and 7 on the 1st.) All are 1 pipe except for 2 radiators on the first floor, which are 2 pipe and one of those a is a baseboard?
Is this normal also how can I tell if it is a Hartford loop? Thanks for any help, Rob
The hartford loop is just a small section of riser pipe about a couple feet tall next to the boiler on the return line that prevents a return line leak from draining your boiler into the basement.
Is that what you are asking about, or maybe a different thing?NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0 -
Thanks for your reply, I’ll try and get an image and upload it to get a better idea.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 48 Industry Classes
- 55 Job Opportunities
