Use heat exchangers in an open trough reservoir?
cgregory
cgregory Member Posts: 6
I can't fit a typical pressure tank into the available space, but can put in a 600-gallon insulated and covered trough for a thermal reservoir. The question is transferring the heat from the boiler to the trough. I'm wondering if I could use a properly-sized heat exchanger with the pressurized boiler loop delivering the heat to a separately-pumped unpressurized loop in the trough. Rather than the 15 psi of the boiler loop, the pump would have the same flow rate, but 2-3 psi or so. Has anybody any experience with this sort of system?
    Jamie Hall Member Posts: 27,367
    Since this seems to be a do-it-yourself type setup (though I can't quite figure out how you have room for a 600 gallon trough, but not a more typical buffer tank...) -- might it not be easier to create your own multipass tube bundle, circulating water inside the tubes from the boiler, and heating the water in the trough?
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    edited December 2018
    Wood guys do this quite often, get a bunch of soft copper, either two or three parallel runs of 1/2L or a couple of 3/4L. Keep in mind that vertical height is key in your storage. If it's a long trough then not nearly as much capacity to efficiently store heat.
    We use 500-1000 gallon propane tanks for this purpose. Usually around a dollar a gallon used. Propane (on any other large pressure vessel) is for pressurized storage and require no HX, think of it like a very large buffer tank.
    hot_rod Member Posts: 27,451
    Check with Tom at this site, he builds custom tanks and heat exchangers, copper to pex.
    http://www.americansolartechnics.com/products/heat-exchangers/
