Was it time to replace this?
bob eck
Member Posts: 930
9 years in a Triangle Tube PE110 Natural Gas boiler. This boiler does heating and domestic hot water with a built in 10 gallon SS IDWH.
This igniter lasted a long time.
Was it still lighting ? Or is that why you were there?
Hopefully the new one will last as long as the old
D0 -
It was on a hard lock out and when it fired you could hear a little boom as to much gas before it would light.0
Yup, time for a new one.All Steamed Up, Inc.
Consulting0 -
I just had the same problem with an 8-year old TT Prestige Solo 110 in Berkeley. Most of the time, the boiler wouldn't light, but when it did, it did a mini-explosion.
The igniter looked exactly like yours; deformed and too large of a gap. New igniter fixed the problem.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
- 120 Geothermal
