out side wood boiler
ferguson35
Member Posts: 2
I keep having with damper solenoids. THey just wont last long
Make and model of boiler? Pictures?0
econo 2000
Ok, well that's a bit vague. What are you looking for? What voltage are you getting to the solenoid, how do they fail etc?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Overheating due to excessive heat from boiler or too much resistance due to shaft not turning freely would be a couple guesses. @ferguson35 , you need to provide more if you really want help."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
