Enlarging Radiators
Peter Rozano
Member Posts: 17
I live in an old farm house. The large room in under radiated. I found a couple of identical ornamental radiators (to comport to the architectural integrity of the building) that were on the smaller side. I disconnected the threaded rods and separated some fins. I lucked out when the connecting collars (top and bottom) matched perfectly. I slathered the connecting collars and receiving holes with Real-Tuff and rejoined everything with longer connecting threaded rods & nuts.
Then came the water test under pressure (I used a garden hose w/ adapters because that would be higher pressure than a heating system). It failed miserably. I could actually hear the air escape from my joint instead of the bleeder valve
What am I missing? The nuts are adequately tightened (at least I believe so). I dissembled & reassembled radiators to make them bigger about 20 years ago and everything worked great. The only differences are: (1) I used Pro-Dope instead of Real-Tuff; (2) I never used the garden hose test before.
Clearly, it is not the pressure from the garden hose that blew out the Real-Tuff because I could hear the air escaping from the joint.
Should I take a wire-wheel brush to this joint (to remove errant paint or rust) and reassemble? Is there a down side to doing this?
You should not use a wire wheel on either the nipples or the mating surfaces in the sections -- you'll scratch them and then they'll never seal. You can clean them up, if necessary, with fine steel wool or emery cloth of something of that sort -- but I'd be surprised if the mating surfaces had much crud on them.
And I don't remember the source for replacement nipples, either...Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1
