Backflow preventers
Mike
Member Posts: 94
Does anyone know if one backflow preventer can feed two different boilers? Can't find any code that stipulate this.
Are you talking about 2 separate closed loops systems? I don't think it is against code. I is not very practical as the systems would share the same water. A leak in one would result in a leak in the other."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
It would see both boilers as one system, unless you added additional checks on both, expansion tanks also.
Same as a single BFD on the main house line feeding multiple connections downstream, I suppose.Bob "hot rod" Rohr
Living the hydronic dream0
