Radiator- What is this?
Nysteamer
Member Posts: 22
Hello all,
Thanks ahead of time. I am trying to figure out what kind of vent this is?
These are two different radiators. I am not certain how they even function.
I have hoffman 1A on all radiators just fyi.
Thanks
Thanks
First one looks like a bleeder valve for a hot water radiator, the other two, I'm not sureYou can have it good, fast or cheap. Pick two0
Unless you have a hot water system, those will not work, and should be replaced with some Hoffmans.—NBC0
They look like hot water bleeder valves w/ the handles/ keys broken off.
If this i8s a hot water system they are too low in the radiator to work.
If it is in a steam system they are the wrong vent. That should be an air vent...0 -
Hey guys, so system is steam, and actually just about adjacent to these little guys is where the vent tapping is and where the hoffman 1a is. I am a hundred percent sure there was never any hot water system in the house before, and I believe almost every rad in the house has one of these in them.0
I've seen this before. I think these were used to manually speed up slow radiators when needed. Nowadays we'd fix this with proper main venting.All Steamed Up, Inc.
Consulting0
