Boiler Expansion Tank Leak- Picture of it!
bschroed
Member Posts: 2
Have a Navien boiler and the expansion tank has been for 2 years, and started leaking, and looking like this. Any ideas what can cause this before I install a new one. It is an EX30 Amtrol, which is a good product.
OK -- what hit it? That looks like damage from the outside...Br. Jamie, osb
Looks kinda like external damage, but where is it located in relation to the circ? What is the system pressure? Even Extrol can't out-engineer a poor install0
What is the rest of your system composed of?
Is there pex tubing in it? Radiant floor? Staple up? What type of tubing is in the system?
What is you water like?
What temperature does the system run at?0 -
Could be oxygen intrusion from non-barrier PEX.
If so, replace it with a potable X-tank.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
