ESBE valve + converted gravity question
gardenweasel
Member Posts: 24
I am adding a bypass to my gravity converted system that came with my house. It's already 25 years old but I'm trying to keep the boiler and my 4-year-old chimney liner as happy as possible.
Was going to do a simple bypass but I got a great deal on an ESBE valve body. The piping diagram, though, looks like I need to have 2 circulators and pump it P/S in order to use on converted gravity. Am I reading this right? The ESBE instructions are hardly comprehensive.
I do worry that if I added the ESBE without P/S that the flow could be so slow through the old gravity pipes that the 3rd floor never gets warm before the thermostat on the 1st floor stops calling.
Am I overthinking this?
You need a circ on the boiler side and a circ on the system side. The drawing has a 3rd one which is unnecessary. The primary/secondary should be tied together with closely spaced tee's or a hydraulic separator.
Albert Einstein0 -
Zman is correct. The ESBE diagram's 3rd circulator is shown with a dotted line around it. The full document indicates that is an alternate, but less desirable, location as compared to being installed on the outlet of the boiler.0
you would need to analyze the circuit. It’s possible a dongle circulator could be adequate for the boiler glue and distribution, on a direct, non primary secondary piping. There are loading units that are a pump and valve in one assembly. Commonly used on wood fired boilersBob "hot rod" Rohr
Living the hydronic dream0
