Exterior Rated Hot Water Boiler Piping Insulation
JasonRowland
Member Posts: 2
I ran into a weird setup where a business that tests explosives has a residential hot water boiler installed in an outbuilding and then has about 15' of above ground 1.25" and 1.5" steel piping running into the building it heats. They run a glychol mix through the system and the existing piping insulation is shot. They want me to replace the insulation but I can't find any insulation approved for this through my local suppliers. All they have is indoor rated. So trying to find something rated to outdoor use. Under the gun a bit since we gotta change out the boiler soon. Please advise.....
Fiborglass with plastic covers. A sealer will he needed to make it water proof0
Yes, @pecmsg is correct. Fiberglass covering with PVC jacket which needs to be sealed and caulked.
If it was me I would hire a professional insulator. I believe you insulation supplier can cut and supply the pvc jacket0 -
Armaflex rubberized insulation is often used for this with a PVC or galvalume jacket. The Armaflex will combat moisture on its own unlike fiberglass0
