Ice balls on chimney flashing?
daveinmass
Member Posts: 6
Hi. I looked up at my chimney today (25 F outside) and saw these ice balls by the chimney on the flashing. I’m new to the house this winter, and the chimney could be repointed and the chimney cap definitely is rusting a little. But I have no idea what this is.
We have a 15 year old furnace (just serviced) and new hot water heater, if that helps. It hasn’t rained hear in a week
Any help? Thanks in advance.
Much more info needed, and photos of your boiler system. What does your boiler temp read? You, or someone, needs to measure the flue-gas temp, and adjust the combustion, accordingly.0
Thanks for the help so far.
I’ve attached another pic of the whole chimney for reference. Colder this morning.
As noted, the furnace is gas and 15 years old. I had it serviced on Friday and the tech mentioned it has 85% efficiency.
Here are the temp numbers from his check (not sure what they are, but here is how they are listed):
Flue F: 290.8
INLT F: 55.7
NETT F: 235.1
Hope that helps. Again thanks for the assistance.0 -
And yeah, the masonry has had a few patch jobs — already scheduled an estimate for May.0
I'd be concerned as to the inside of the chimney. Is it a clay tile liner? Or no liner at all?
This could be the reason the masonary is in rough shape. The flue gases condensing are acidic, and will eat at the masonary.
Back in the day of equipment with high stack temps it wasn't as much of a concern since the condensate would be burned off. With higher efficiency equipment with Lower stack temps chimney lining is a requirement to protect the masonary.1 -
Thanks Gordy. Looks like a clay liner, but I’ll add that to the list to make sure it gets checked in the spring.0
Clay liners are subject to acidic corrosion also. If they are misaligned flue tiles that leak the exhaust gase they will seep into the masonary. Also that chimney goes through the interior of your home. So if there is a breach in the masonary it could allow co into the living space.
Not trying to scare you, but the exterior of the chimney is in poor shape due to the corrosive flue products eating away at the masonary. Probably most of the damage was done before a chimney cap was installed.0 -
Pic of the top of the chimney? Also, its "masonry" guys. Yes, Gordo covered it pretty well.0
Hi Bob. Attached is a pic of the top of the chimney from a few weeks back. I’ve got a replacement, stainless steel cap—just arrived and now I’m waiting for the weather to be warm enough during the day to do a swap.
But yeah, you can see the masonry grout needs some work.0 -
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
- 47 Industry Classes
