Toilet ballcock connection size
ChrisJ
ChrisJ Member Posts: 17,400
edited December 2018 in Plumbing
Hi all.
Is the supply connection to toilet ballcocks and fill valves a standard size? Are there or were there different sizes over the years?
I have a 1960s American Standard and I need to make up a test hose so I can supply it with water outside to work on it.
I'm just going to leave it at that. :P.
  • It's a strange size: 7/8" IPS
    ChrisJ
  • JUGHNE
    JUGHNE Member Posts: 11,552
    WC riser flex tube would give you a transition from 3/8" compression to WC connection.
    ChrisJ
  • ChrisJ
    I'm assuming they're all the same size then?
    Even a 1940s setup? Commercial (non-Sloan) and Residential?
  • EzzyT
    EzzyT Member Posts: 1,379
    All American made toilets ballcock connection size has been 7/8” for over 100+ years.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    ChrisJ
