Toilet ballcock connection size
Hi all.
Is the supply connection to toilet ballcocks and fill valves a standard size? Are there or were there different sizes over the years?
I have a 1960s American Standard and I need to make up a test hose so I can supply it with water outside to work on it.
I'm just going to leave it at that. :P.
I'm assuming they're all the same size then?
Even a 1940s setup? Commercial (non-Sloan) and Residential?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
All American made toilets ballcock connection size has been 7/8” for over 100+ years.-1
- 117 Geothermal
