LENNOX MODEL# HP25-311-1P CONDENSER
WHAT ARE THE DIMENSIONS OF THE UNIT
  • THANK YOU FOR THE HELP. IT ONLY 24 HOURS LATER AND NO REPLIES.
  • Turn off your caps lock. Try looking at Lennox's website for this information.--NBC
  • ratio
    ratio Member Posts: 4,176
    It looks like this is a c. 25 yo heat pump, so not a new install. Could you ...measure it?
    Or, did you mean the specifications, for a replacement? It looks like around a 3 ton unit, but it's not going to be a direct swap, you'll want to get a competent contractor to size it, as well as make the necessary changes to the remainder of the system (lineset & indoor coil specifically)
    And please do turn off the caps lock. It's quite distracting, and some find it insulting.
  • John Mills_5
    John Mills_5 Member Posts: 952
    You could try at hvac-talk.com and see if member rundawg sees the post. He has literature on everything sold in the last 40 years. Lennox has thinned out their obsolete collection, I couldn't find it on there.
