LENNOX MODEL# HP25-311-1P CONDENSER
kathyguccidevaughn
Member Posts: 2
WHAT ARE THE DIMENSIONS OF THE UNIT
THANK YOU FOR THE HELP. IT ONLY 24 HOURS LATER AND NO REPLIES.
Turn off your caps lock. Try looking at Lennox's website for this information.--NBC0
It looks like this is a c. 25 yo heat pump, so not a new install. Could you ...measure it?
Or, did you mean the specifications, for a replacement? It looks like around a 3 ton unit, but it's not going to be a direct swap, you'll want to get a competent contractor to size it, as well as make the necessary changes to the remainder of the system (lineset & indoor coil specifically)
And please do turn off the caps lock. It's quite distracting, and some find it insulting.
You could try at hvac-talk.com and see if member rundawg sees the post. He has literature on everything sold in the last 40 years. Lennox has thinned out their obsolete collection, I couldn't find it on there.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 969 Plumbing
- 385 Solar
- 15.3K Strictly Steam
