What is this?
SeanBeans
Member Posts: 520
On the 8th floor of a 15 story building, heating stack.
Maybe some badly encrusted insulation?All Steamed Up, Inc.
Consulting0 -
It’s solid metal and it was leaking from somewhere inside the bigger metal sleeve.
It has a tag!
You can access the valves from the cover, it steamed up to the 11th floor and leaked down to the 1st0 -
I would agree with that, I marked this up a bit to complete the letters that could be seen. I see Expansion Joint on the label. And yes I know my "handwriting" is terrible.EzzyT said:Looks like a expansion fitting
Here you go.
Can anyone find any literature on it?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
