Fixing pitch issues in old house
Thanks everyone, I think I can swing it LOL!
Thanks!
I finally found a picture of the original blueprint showing the front bedroom as original to the house and thought you might like to see it.JUGHNE said:Also some houses had an outside screened sleeping room for the summer. They would have an outside door going out to the "balcony". The floor would have been sloped to drain rain out away from that door thru scuppers, drains thru the bottom of the 1/2 wall to spill water out on the shingles. Could that have been the case with your dormer room? The construction for the floor would have been only for porch load, like your main porch....a little less than the actual house construction.
I did edit this photo to show converting the left bedroom into a dressing room, but it does show the overhanging part as a real room.
Editing this post rather than replying so that it doesn't bump it to the top: Here is the end of the story, thanks all!: https://forum.heatinghelp.com/discussion/177777/autumn-saturday-radiator-repipeNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
