short term overhead oil supply line
jozi
Member Posts: 2
Hello. I have an existing oil heat system with an interior tank where the 3/8 supply line is roughly a 30' run. The line runs at ground level ,partially exposed and partially under concrete. The basement will be having a perimeter floor drain system installed and the line will be in harms way during process. I am aware of some of the pitfalls of an overhead line, but was hoping to possibly run a line overhead for 2-3 days until the bulk of the work is done & then drop it back down to the floor. If run overhead it would be about a 7 foot rise. Any input would be greatly appreciated. Thanks Joe.
If you can keep it lower that would be better. If your system is residential the fuel unit is likely single stage / single pipe and that should not exceed 6” of vacuum the rise you are referring to would exceed that. It’s 1” of vacuum for every 1 foot of lift. And that does not even take in account for any filter and fittings, which would also be 1”
-1 -
Thanks Alan, I've decided this is probably a job for a professional. I am extremely confident in my mechanical ability, but have just enough knowledge to get myself in trouble.0
