Gorton valve horizontally. Steam radiator
igorvin
Member Posts: 2
My super installed a Gorton Straight valve horizontally in my radiator which had an angled valve before. Is this going to cause problems? Thanks in advance for the answer.
post a picture, but, yeah,
your super is having a bad day.known to beat dead horses0 -
Picture would be good, but if they did what it sounds like then yes it will be a problem.
If they can't get that basic concept correct, makes one wonder what else is probably wrong.0 -
No good. The Gorton has a float in it and to operate properly the can must be vertical -- that is, with the connection to the radiator on the bottom, connecting through a 90 degree elbow, and the vent opening on the top.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1 -
That's hysterical.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
They sure are raising the bar for stupidity on steam. I know it's not necessarily in keeping with this site, but a wall of shame sure would be fun.JohnNY said:That's hysterical.
