Aquastat problem
JQuk89
Member Posts: 3
in Gas Heating
I have a Honeywell L8148E aquastat there is voltage between W & B2 but none between W & T,.the owners manual shows something between these two terminals that is marked 1K, is this a resistor?
You're measuring in the wrong spot. You're lucky they are both low voltage terminals.
Be careful or you are going to short it, at best.There was an error rendering this rich post.
Why no voltage on T or TV can not get power to the pilot control.0
Can not get voltage to pilot control jumpered T & TV to over ride termo still nothing on L8148 aquastat.0
It may not be your aquastat, if that unit has a motorized vent damper call a pro.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
