Electric baseboard thermostat
Zipper13
Member Posts: 229
Not sure if I'm in the right place for this question or not.
My house is mostly steam heat, but prior owners put on a small addition And turned an upstairs closet into a bathroom. These new rooms have electric baseboard heat.
Heaters work fine, but thermostats are crummy. Especially in the bathroom. It only functions as an on off switch at the moment so I want to replace that one.
I'm handy enough not to kill myself swapping it out, but not well enough informed to pick out a replacement.
Any thoughts?
Attached are pictures of the the spec label on the heater (the bathroom only has one of the smaller baseboard units) and the existing thermostat.
Any thoughts?
New owner of a 1920s home with steam heat north of Boston.
Just trying to learn what I can do myself and what I just shouldn't touch
These would be a nice upgrade https://www.supplyhouse.com/Honeywell-TH114-A-240D-B-Non-Programmable-Line-Volt-Thermostat-for-Electric-Heating
They have a programmable model as well"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 50 Industry Classes
