Is this a new way to pipe a boiler
Snowmelt
Member Posts: 1,454
no, they've been piped wrong for years0
It is, if you don't read the instructions.All Steamed Up, Inc.
Consulting0 -
Follow up question, the pipe to the left you can see it reduces to two inch but the piping to the rest of the building is 3 inch. The somewhat equalizer on the right is in two inch for about 15 to 20 feet then go back to 3 inch. I wrote in a previous post, will that effect the steam going to its proper places quick enough? With the pipping with no equalizer make the steam / water do all kinds of funky things. I didn’t even get to the other steam boiler yet.0
You need a full repipe and also need to rid all the copper.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......2 -
It's what happens when the installers flunked reading0
About 4 years old ....... customer know that it’s not done correctly, has to get money to do it correctly.0
