Is this a new way to pipe a boiler
Snowmelt
Snowmelt Member Posts: 1,454
edited November 2018 in Radiant Heating
  • ch4man
    ch4man Member Posts: 298
    no, they've been piped wrong for years
    Steamhead Member Posts: 18,497
    It is, if you don't read the instructions.
    Consulting
  • Snowmelt
    Follow up question, the pipe to the left you can see it reduces to two inch but the piping to the rest of the building is 3 inch. The somewhat equalizer on the right is in two inch for about 15 to 20 feet then go back to 3 inch. I wrote in a previous post, will that effect the steam going to its proper places quick enough? With the pipping with no equalizer make the steam / water do all kinds of funky things. I didn’t even get to the other steam boiler yet.
  • coolfx35
    coolfx35 Member Posts: 77
    Snowmelt said:
    how old is this boiler, if I may ask, is there a problem with it?
  • Dave0176
    Dave0176 Member Posts: 1,178
    You need a full repipe and also need to rid all the copper.
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    Specializing in Steam Heating, Serving the residents of New Jersey
    https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
    https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
    1MatthiasSuperTech
    EBEBRATT-Ed Member Posts: 20,177
    It's what happens when the installers flunked reading
  • Snowmelt
    About 4 years old ....... customer know that it’s not done correctly, has to get money to do it correctly.
