A cleaning tool I need!
hot_rod
Member Posts: 27,473
Beats a wire brush! I do hope it never makes it to Walmart though. Imagine that in the hands of an unhappy teen!
Yours, Larry0 -
What kinda dough we talking...?
I need that for my '59 Ford!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
If you have to ask, you can't afford it. The 50W version is about $53K ($53,000!), so the 1000W version in the video probably has an even more nosebleed-inducing price.STEVEusaPA said:What kinda dough we talking...?
Big bucks for one that will do anything meaningful......
Yep. Optics are really bloody expensive.0
Well let's all chip in!! We'll pass it around, take turns...lol1Matthias said:
2 -
Still some conventional prep work after the laser strip.0
@STEVEusaPA ok! I'll post my "$100" how long do I get to keep it?
Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I see some future possibilities in bridge work when repainting steel beams. The old paint is lead base from pre 75 ish. The painters go through a lot to contain the lead, and sand, during sand blasting the old paint off. Then they have to dispose of it.
However this method would still involve containing the fumes from the paint burning. I would think a vacuum system with filtration would be a little easier than tarps making a containment under a bridge. Then retrieve the spent sand, and paint from tarps on the ground.
- 120 Geothermal
https://www.youtube.com/watch?v=Q8q3DZB_l6M
