A cleaning tool I need!
hot_rod
hot_rod Member Posts: 27,473
Rich_49IronmanSolid_Fuel_Man
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,103
    Beats a wire brush! I do hope it never makes it to Walmart though. Imagine that in the hands of an unhappy teen! :o
    Yours, Larry
  • STEVEusaPA
    What kinda dough we talking...?
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    I need that for my '59 Ford!
  • 1Matthias
    1Matthias Member Posts: 148
    If you have to ask, you can't afford it. The 50W version is about $53K ($53,000!), so the 1000W version in the video probably has an even more nosebleed-inducing price.
  • Gordy
    Gordy Member Posts: 9,546
    Big bucks for one that will do anything meaningful......
  • 1Matthias
    Yep. Optics are really bloody expensive.
  • SuperJ
    SuperJ Member Posts: 609
    I bet it would make a great shaver.
    Solid_Fuel_Man1Matthias
  • STEVEusaPA
    edited November 2018
    Well let's all chip in!! We'll pass it around, take turns...lol ;)
    1MatthiasSolid_Fuel_Man
  • Gordy
    Still some conventional prep work after the laser strip.
  • Solid_Fuel_Man
    @STEVEusaPA ok! I'll post my "$100" how long do I get to keep it? :#
  • Gordy
    Not as long as it will take to round up 85k :D
    Solid_Fuel_Man
  • Gordy
    I see some future possibilities in bridge work when repainting steel beams. The old paint is lead base from pre 75 ish. The painters go through a lot to contain the lead, and sand, during sand blasting the old paint off. Then they have to dispose of it.
    However this method would still involve containing the fumes from the paint burning. I would think a vacuum system with filtration would be a little easier than tarps making a containment under a bridge. Then retrieve the spent sand, and paint from tarps on the ground.
    Solid_Fuel_Man
  • Gordy
    I’d like to know maintenance costs for this. How long before things need replaced at what cost.....duty cycle also. I’m quite sure you just can’t pull the trigger, and run for long periods.
    CLamb
