Condensate tank piping?
Mike
Member Posts: 94
Come across this piping arrangement for the condensate tank venting. I've never seen this before. Can anyone give a explanation, of what it is to do? Piped
From the header into the vent pipe.
Check valve in that dropped pipe. I believe they are using it for a vacuum breaker. They piped it that way so if the check valve leaks backwards the condensate will go into the condensate pump0
- 50 Industry Classes
