Condensate tank piping?
Mike
Mike Member Posts: 94
Come across this piping arrangement for the condensate tank venting. I've never seen this before. Can anyone give a explanation, of what it is to do? Piped
From the header into the vent pipe.
    EBEBRATT-Ed Member Posts: 20,259
    Check valve in that dropped pipe. I believe they are using it for a vacuum breaker. They piped it that way so if the check valve leaks backwards the condensate will go into the condensate pump
