Help chosing boiler for radiant floor heating.
BBBSS
Member Posts: 2
I'm in NW Chicago and need to replace a Weil McLain CGM-3 from the late 80s/early 90s with a DOE of 55,000 BTU for radiant floor heating in a basement apartment. The apartment this heats is supplemented with forced air from the apartment above. The current boiler is vented through the wall.
I called the company I usually use for my HVAC needs but they seem to recommend another contractor for boilers. They have recommended a Burnham / US Boilers X2 03 for an easy replacement. I can't seem to find any info on this Burnham/US Boiler X2 model online. Is this a newer model or is it a new model name now that they are part of US Boiler??
I'm mainly concerned about long term reliability and ease of getting parts / doing my own maintenance and repairs. The Weil was easy to work on and very straight forward and I liked that. I don't mind paying a bit more for a quality unit up front and I want a basic setup not a high efficiency or anything that would require an extensive install. Simple and reliable!
I appreciate any input on the X2 or anyy other brands/models I should look into.
Thank you!
Thank you!
Heres a few pics of the old setup. Looking for something that could slip into its place easily hopefully.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
