Should there be a buffer tank on this type of job?
@NY_Rob my design is based on the Sterling Heattrim Plus on 2 floors (output table posted above), and the standard Heatrim on the top level which has lower heat loss.NY_Rob said:^ is your design based on HE2 or conventional fin-tube?
Curious as to the heatloss/sqFt of a new build modern home?
My 1960's 2x4 construction home comes in between 15-20 BTU/SqFt.
My house is a 1965 split, 2x4 construction, but it was built with electric heat, so a lot of attention was paid to insulation, doors and windows. Design spreadsheet is attached.
Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg-1
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
