Interesting Hot Water Manifold
New England SteamWorks
Member Posts: 1,528
I just received some advanced photos for a hot water job I am going to look at soon. The manifold looks quite interesting, and I am wondering if anyone has any insights? Looks like I should be able to convert it to 3 zones, right now it is just one. There's a big expansion tank in the ceiling, which we'll of course remove.
Thanks!
Thanks!
newenglandsteamworks.com
Rut-roh...I wonder who has something to say about it...lolNew England SteamWorks said:...There's a big expansion tank in the ceiling, which we'll of course remove...
4 -
Looks like the boiler has been replaced before? Nice collectible piece, that header.Bob "hot rod" Rohr
@STEVEusaPA that was at the forefront of my mind as well!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
I am guessing there has been more than one replacement boiler since the original...New England SteamWorks
newenglandsteamworks.com0 -
We haven't done a water boiler in a very long time, and we really didn't enjoy all the purging and radiator bleeding. Still, it was a pleasant change in the routine, and came out nicely.
It's a wrap!
That's quite a piece, judging by the gauge, it is old, old!Bob "hot rod" Rohr
What is there to prevent the boiler from condensing? I imagine w/ that much water content it will be in condensing mode for a good while.0
Look at you 'slumming it' with a water boiler... Looks nice.
Is that exp tank ok hanging like that?There was an error rendering this rich post.
I'd be worried about the size of the compression tank too. If that's the typical gravity system, especially with columnar rads, they hold a lot of water. Fortunately they don't get too hot usually, but a tank bigger than a #30 usually is needed. I have had to use floor mounted tanks or 2 to 3 #30, or 60's in some systems.
Steam can be a lot easier to installed in many ways.... you don't have to watch out for condensation or cold or hot shocking nearly as much.To learn more about this professional, click here to visit their ad in Find A Contractor.1 -
I just think those steam guys are not used to figuring the weight of water in their pipes! Think of the whole system as a wet return....minus the corrosion!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
