Self-sealing insulation safe adjacent to boiler?
david_and_heather
Member Posts: 32
Previously, I asked whether it was safe to put pipe insulation right up to the point at which the pipe goes into the boiler. I was advised that I can and should put fiberglass insulation right up to where the pipe comes out of the boiler. I am lazy and I never did it. When I went to buy the insulation, I found that all of the insulation seems to be the "self-sealing" type installed higher up, which is surrounded by paper. Is this safe for that paper to go right up to where the pipe meets the boiler? I should say that the water line is about a foot below the place where the pipe comes out of the boiler.
Also: how do you insulate the elbows?
I can only tell you that I've seen plenty of installations where they insulate right up to the boiler.
Youtube has a lot of videos on installing insulation like this one:
https://www.youtube.com/watch?v=qhO9ZRsEcmU 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thank you!0
Yes I did
Can you share your source for that insulation? And I’m afraid to ask your expected payback decade 😅
