Aquastat sensor won’t come out of well
Help please.
I’ve replaced the aquastat on my Superstor before, but this time I cannot get the sensor out. It feels like it’s corroded against the side of the well.
I have been spraying Liquid Wrench into the well and tapping the sensor with a thin screwdriver, but it won’t budge.
Any advice? Do I need to drain my tank and replace the well along with the new aquastat?
Thanks,
Sent from my iPhone
  • I'd grab onto that sensor with a good pair of electricians pliers, place another pair of pliers at the face of the well and underneath the first pair of pliers and try to leverage that sensor out.
    If the capillary tube breaks off, replace the well.
  • HomerJSmith
    HomerJSmith Member Posts: 2,770
    edited October 2018
    Is it an aquastat or a sensor?
    You did loosen the screw all the way and make sure the retaining clip is uncoupled from the well before pulling it out. If you used heat transfer paste on the bulb, it may have hardened. You can try and soften the paste with lacquer thinner. Give it time to work.
    HVACNUT Member Posts: 7,378
    Was is leaking from the well and that's why it needs replacing?
    Super Stor requires a stainless well. Is that what you have?
  • Uhhlewcid
    Uhhlewcid Member Posts: 1
    Coming back to this forum after fighting my own stuck sensor. 3 hours later and PB blaster will soaking through enough to eventually break down the paste.
    20241227_042807.jpg 20241227_115949.jpg 20241227_161419.jpg 20241227_161421.jpg 20241227_175520.jpg
    I was never a fan of the paste. Now to replace the well.
    SuperTechAlan (California Radiant) Forbes
