Watts temp/press gauge.
nibs
Member Posts: 516
With the Rinnai boiler we are installing, came a Watts temp/press gauge with no directions for use. It is in two pieces and Watts in their wisdom has decided that I cannot be trusted with assembly directions.,
Question, how far do you screw the gauge into the DPG-VR retaining piece. Does it screw in until the gauge shows movement, or does it just screw in snug. Don't want to break anything, and would like to put it in this afternoon.
Thank you, Tony
Thank you, Tony
I found no instructions on line. I would say use pipe dope on the retaining valve to install it in the boiler then screw the gage into the retaining valve just until snug. Check for leaks0
I use a lot of those. Whether right or not, I haven't yet broken one or had a leak. I put the snubber in first with a thin layer of Permabond, then the probe with another thin layer. Spin the gauge with my hand until tight, then spin the snubber another 1/4 to 3/4 turn to the right orientation with a 6" Crescent wrench.1
Thank you both, the gauge is in, hopefully it wont leak, began pressurizing the system this afternoon, once I had the gauge in.0
