American Standard GPH
michaelheit
Member Posts: 11
in Gas Heating
Hi
I have a American Standard GPH Hydronic boiler and I need some help.
I was working fine in the spring before the warm weather.
I did not turn off the pilot so that is not an issue.
What I did do was take out all the burner tubes and clean them. I also tried to clear the the jet hole with a small paper clip.
When i started it there was a wooshing and I yellow flame out the front.
I boiler has 8 tubes for flame and I thought they were all the same.
I think I may have been wrong.
I think i put then back in a different order. Also I have since learned that each tube has a air mixture adjustment and I may have messed this up as well.
I also was wondering If there is a tube that MUST sit next to the pilot light and is just a little different from the others.
any help and I would be grateful
michael
michael
Picture of the burners and pilot location would maybe help.0
OK
I will post those tonight0 -
Positioning the burner with pilot assembly in its original place is important. If the crossover bars on the burners aren't aligned properly, you'll get a rough light off - delayed ignition. If you accidentally closed off the primary air shutter on a burner(s), you'll get yellow flamesSteve Minnich0
Any chance there is too much primary air. The orifice is at least an inch way from the burner opening. The adjustment on each tube is an insert in the tube with a set screw which allows the tube insert to be pulled in and out of the tube, thus reducing the gap between the jet orifice and the tube mouth. As for the paper clip I think i was careful not to bend for alter there opening. I hope i did not ruin them. But do you think that replacements are still available if I did screw them up.0
Also does any one on the site know of a service person who is familiar with this system on Long Island NY. I would like to keep the system as I like its simplicity and that every person who has seen it seems to really like old cast iron boilers and how they were made. Also I dont have the money right now to do a replacement of the entire system.0
Pictures....burners....pilot.....gas valve and regulator.0
Ok Jughne. I promise tonight0
check find a contractor on this site. there are a few in your area0
Here are the pics
Forgot the overview image
