Old Pilot Assembly
Positive Solution
Member Posts: 21
in Gas Heating
I have an old Weil Mclain boiler with the large iron burner tubes. See attached photos. My client wants to convert to spark ignition but I cannot locate a spark ignition pilot assembly that will work on this burner tube. Any suggestions?
Pictures??0
And still no pictures?0
The Honeywell Y8610U comes with adapters that will fit most pilots. If you are going to switch from standing pilot to intermittent pilot you have to get a retrofit kit Honeywell and Robertshaw both offer Kits that can fit most anything.0
How to add an attachment
If you’re on a desktop computer or a mobile device:
When in New Discussion, click on the document icon
Choose files or enter an image url0
- 116 Geothermal
- 15.8K Strictly Steam
