Old hot water heating system with cast iron radiators
djfreni
Member Posts: 13
I have a customer that has a 20 year old Wiel McClain boiler. It has a small Taco 007 circular on it with two heating zones with zone valves. She has a problem with one huge radiator on the 1st floor dining room not heating up much at all, but the exact same radiator in the living room right next door is blazing hot. Should I put in a bigger circulator like a B&G 100 series?
Have you tried bleeding the cold radiator?—NBC0
Vent the radiator. Is the radiator valve open? The old radiator valve could be broken and you might think it is open and it might not be open.0
New problem with that radiator or long time issue?
Long time issue. Valve are wide open and no air in any radiators0
Use a laser thermometer to measure the temperature drop from supply to return on each radiator. Using the shut off valves, try to even them out to steal flow from the over-pumped radiators to the underperforming unit. Balancing is an often overlooked part of the hydronic heating process.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes3 -
Piping is all oversized. Probably gravity system way back0
Thankyou JohnNY0
If this is a converted gravity system it could be possible there were originally restrictor baffles in the radiator in question that were never removed in the conversion.
I find it all most hard to believe that this was a problem from the initial conversion though. But weirder things have happened on new installs left as fully functioning work.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
