Paloma Pak not firing
sameul92
Member Posts: 1
I have a Paloma Pak Model PP-16N boiler. The pilot is on and batteries have been changed in the thermostat and it does not seem to fire. I used it just last week and the next day, it's not firing. The pilot is on but nothing fires for the heat to work. What could it be?
plugged filter is common, the manual should explain troubleshooting steps and plenty of You Tube on troubleshooting, service and repair procedures.Bob "hot rod" Rohr
Living the hydronic dream0
