Paloma Pak not firing
sameul92
sameul92 Member Posts: 1
I have a Paloma Pak Model PP-16N boiler. The pilot is on and batteries have been changed in the thermostat and it does not seem to fire. I used it just last week and the next day, it's not firing. The pilot is on but nothing fires for the heat to work. What could it be?
    hot_rod Member Posts: 26,580
    plugged filter is common, the manual should explain troubleshooting steps and plenty of You Tube on troubleshooting, service and repair procedures.
