Lochinvar DVN076
reg35
reg35 Member Posts: 1
edited October 2018 in Domestic Hot Water
Lochinvar DVN076 NO HOT WATER AND EXHAUST FAN RUNNING WOULD REPLACEMENT OF PILOT WORK
  • JUGHNE
    JUGHNE Member Posts: 11,549
    On most power vented appliances, the exhaust fan has to satisfy a pressure switch, then go to the next step of ignition.
    The first simplest thing is to assure that the exhaust pipe and air inlet (if applicable) outside is clear.
