Lochinvar DVN076
reg35
Member Posts: 1
Lochinvar DVN076 NO HOT WATER AND EXHAUST FAN RUNNING WOULD REPLACEMENT OF PILOT WORK
On most power vented appliances, the exhaust fan has to satisfy a pressure switch, then go to the next step of ignition.
The first simplest thing is to assure that the exhaust pipe and air inlet (if applicable) outside is clear.0
