Buzzing gas boiler
billybongo
Member Posts: 6
in Gas Heating
My 1970's gas boiler is making an intermittent buzzing noise.
This is only whilst it is heating up/operating.
I have uploaded a video of it here -
https://youtu.be/0xKV4vOvr2w
Any suggestions much appreciated!
https://youtu.be/0xKV4vOvr2wAny suggestions much appreciated!
Its likely the coil for the relay.
It's also likely your boiler wants an appointment with Dr. Kevorkian.0 -
hehehe thank you for the replies. I may let nature take it's course...0
I have had a quick look for the relay serial number and nothing for sale.
I'm finding similar Honeywell relays. I need 40 VA and 27 Volt secondary. Would a relay with 38VA and 26.5 volts do the job?0 -
Sometimes if you move/push on the relay box or the relay itself (remove cover) you maybe able to make the sound go away.
That is also known as a fan center. I'm not sure if it is a dpdt, or a spdt, or other. If that is just controlling the burner, the 38 or 40va is fine. Description should be on the paper attached to the cover if you still can read it.0 -
Ah thanks for the tip. I will try that tomorrow.
The paper label is legible but no word on the poles.
Maybe I can find just the relay if there is any part number on there when I take it off. Too late and chilly for that tonight!
You can use what's called a
Fan Center Control Relay.
It's a 115v primary, 24v, 40va secondary and is attached to a 1900 plate that will fit on the existing junction box.
Connect R and G to the thermostat and a N.O. -| |- Contact on the relay for the burner circuit. Follow the schematic, and when done, try it with the gas off first.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
