Glycol Calculations
KeenGreen
Member Posts: 27
I am trying to find a simple formula to calculate the amount of glycol in a heating system.
My customer has 3300' of 5/8" oxy tubing, 12' of 2" copper with a number#30 expansion tank.
Glycol will be 50%.
Does anyone have a simple calculator available?
Thanks in advance.
Jeff
Glycol will be 50%.
Thanks in advance.
Jeff
What about the boiler capacity, it could be the largest number?
35-n40% is usually adequate, unless you expect -50 below inside
Glycol doesn't transfer heat as well as water and requires more pumping power, as well a fluid maintenance.
Select a top brand$$ with good inhibitors and blend to a reasonable protection %.Bob "hot rod" Rohr
no idea on tank.
But just because it's interesting to see the numbers on long tubing .....
Tubing Volumne = length x cross section area ( using ID)
1728 cubic inches = 1 cubic foot = ~7.48 gal
3300' of 5/8" oxy tubing ..... assuming it's 1/2 ID that internal volume is:
77715 inch^3 = 4.497 ft^3 = 33.6 gallons .
I don't know oxy tubing.....Measure ID of your tubing.
If it's 5/8 inch ID then it's 52.5 gal
12' of 2" copper...... assuming it's 2 inch ID that internal volumne is:
452 in^3 = 0.26 ft^3 = ~1.96 gallons
Measure your pipe ID.
I get 35.6 gallons of system capacity plus your boiler or heat exchanger. You can find their volume from the manufacturer.
So far 35.6 x .5=17.8 gallons @50% glycol.
Their is no calculator it's all math-1 -
Use the commercial sizer program at Amtrol, it allows for glycol %, as that will change tank size.
amtrol expansion tank sizerBob "hot rod" Rohr
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
